Civilstorm does't compute when i validte the meseage appears no validation issue it says but when i compute it does't work the measage dialoge box apear it says eror
Gerawork mulu,
When you get the error message(s) after Computing, you should see a User Notification window containing specifics about the error(s) encountered. If you don't see the User Notification window, please click Notifications in the Calculation section of the Home tab of the ribbon bar. The window should appear containing the messages about the errors found.
You can right-click or double-click each error (if it pertains to a specific component in your model) and "Zoom to" the component and see/fix the Properties for the component.
If you still have questions about the cause of the errors or how to fix them, you can use the File - Save to Package tool to create a zip file of the files required to open the model (the .stsw and .stsw.sqlite files) and upload the zip file for us to review. Use this link to upload the files and then post back here to let me know the file has been uploaded for review.
Thank-you,Larry
Larry Abla
Thank you for your immediate response
I tried to correct the error which appear as a message and also I validate the issues and it says no validation issue. but when i perform the computation it says error. Here below i have attached the file.
thank you
.gerawork final12.stswpkg.zip
Jesse, would you sent me the result that you compute at this time i need the result up to fixing the problem.
Than you
Gerawork
Can you be more specific please? What results are you looking for? Did you check your license status? Please provide details on what you see for the status, whether you can upgrade (and the result of upgrading if you did), your CONNECTION Client version number, a screenshot of the Feature Level Selector, etc.
computation results like catchment total out flow for each catchment,(resend me the model you computed what i sent you before and i will take the result from flex table License status .
Here is a copy of the model including the output file:
gerawork final12_SavedWithResultsbyBentley.stswpkg.zip
However, it is saved in the latest version and you may not be able to open it in your older version without upgrading first.
Regarding your screenshot of the About window - it is unusual as it does not have any identifying information. Are you using a checked out license? Does your organization own a license? Check the CONNECTION Client (running in your system tray) to ensure you are signed in, and also check the "Bentley Licensing Tool" (search in your Start menu) to view details of the license status.
Jesse,
Thank you for your support
The file is not open by the older version what i used but i can't update the latest version. if you can run by the oldest version 10.03.03.44 send me the zip file.
Thank you in advance!!
