Civilstorm does't compute when i validte the meseage appears no validation issue it says but when i compute it does't work the measage dialoge box apear it says eror
Jesse, would you sent me the result that you compute at this time i need the result up to fixing the problem.
Than you
Gerawork
Can you be more specific please? What results are you looking for? Did you check your license status? Please provide details on what you see for the status, whether you can upgrade (and the result of upgrading if you did), your CONNECTION Client version number, a screenshot of the Feature Level Selector, etc.
computation results like catchment total out flow for each catchment,(resend me the model you computed what i sent you before and i will take the result from flex table License status .
Here is a copy of the model including the output file:
gerawork final12_SavedWithResultsbyBentley.stswpkg.zip
However, it is saved in the latest version and you may not be able to open it in your older version without upgrading first.
Regarding your screenshot of the About window - it is unusual as it does not have any identifying information. Are you using a checked out license? Does your organization own a license? Check the CONNECTION Client (running in your system tray) to ensure you are signed in, and also check the "Bentley Licensing Tool" (search in your Start menu) to view details of the license status.
Jesse,
Thank you for your support
The file is not open by the older version what i used but i can't update the latest version. if you can run by the oldest version 10.03.03.44 send me the zip file.
Thank you in advance!!
