Hello, I am trying to export a surface model from Civil 3D to SewerGems for a university project but when I export the .xml file to SewerGems it is misaligned to to my background layer. The red outline should be shifted to the right to enclose the coloured background layer. Any help will be much appreciated!
Liam,
In addition to Scott's answer, if the background layer is an image file (like a PNG of JPEG), note that you may need to adjust the coordinates of the image corners to align with your terrain model. See: Inserting an image background layer in the correct location
