I am importing customer meter data via modelbuilder. Once, I successfully do that and all my customer meters are in the right location spatially, I used loadbuider wizard to allocate demands to the nearest junctions. I did this in a new demand alternative. The spatial allocation worked perfectly but the demand data in the customer meter gets lost and shows as 0 gpm. Not sure what is the issue here
Thanks.
Hello VM,
When using Loadbuilder to assign customer meters to junctions, it is typically best to choose to update the existing Demand alternative rather than create a new one. If a new Demand alternative is created, the demand data imported through ModelBuilder will be lost, unless the correct parent demand alternative is selected.
Please see Customer Meter Elements and the External Customer Meter Data Manager article for more details
