Calibration Help
Hello!
I'm tring to calibrate my model with my field data, i already put a VSP for my pump and i got the error "Pump cannot deliver flow or head", when i change the values of the pattern sometimes i got the error and sometimes not, is there any form to find out the adequate pattern form my pump without field data on the downstream of the pump? The best way it's to test various speed factor on the pattern?
  • Hello Fabio,
    Information on that user notification can be found here: User Notification: Pump cannot deliver head or flow . Generally it means that the pump is operating on the curve, but outside of the values in you table. This could occur with variable speed pumps as well. See this link for more information modeling variable speed pumps: Using Variable Speed Pumps in WaterGEMS and WaterCAD:
    Pattern-based VSPs are typical when you know how the relative speed factor will change with time. If you are using the pattern as a way to calibrate the model, this is not a method I have seen used before. Typically, you would make adjustments to roughness values in the pipes to make changes to headloss.
    I would recommend reviewing the following link related to model calibration: Water model calibration tips. If you are using WaterGEMS, you could also explore using Darwin Calibrator to help with the model calibration.
    Scott
    Answer Verified By: Fabio Lobo Araujo
  • Thanks Scott! Usually i run calibrations making adjustments on roughness values, but in this case my Hazen-Williams coefficient it's already really low, the adjust results in values of 100 or 105 for the coefficient, and the pressue values still aren't equivallent to field data, i think that these Hazen Williams values are not coerent with the field, the system of the city has like 64 years, the material it's PVC, it's there any possibly that my coefficient goes under those values?
  • You should not assume that C-factor is the only adjustment to your model to improve calibration. There are many sources of discrepancies between the model and the field data. Here is a list of some. You need to be an engineer and a detective to calibrate a model.
    Table 1-1. Sources of Discrepancies
    Physical
    Pipe size/location
    Pipe connectivity
    Pipe roughness
    Pressure zone boundary
    Pump curves
    Pipe material/age in GIS
    System changes since model built
    Elevation data
    Operational
    Valve open/closed/throttled status
    Control valve operation/settings
    Transient events
    Actual operations not matching control rules
    Unusual operations when data were collected
    Tank water levels
    Pump status/speed
    Lack of sufficient sensors/gages
    Water quality reaction rates
    Air blockage in pipe
    Demands
    Spatial allocation
    Model does not reflect conditions when data collected
    Large customers with atypical demand patterns
    Not accounting for seasonal changes in demand
    Data
    Inaccurate/uncalibrated gages/meters
    “Latched” data from SCADA
    Understanding SCADA data – average vs. instantaneous
  • Thanks Tom!!
    It's reasonable to use the item "Pump Status/Speed" to calibrate? Do you already see any calibration by changing speed factors of the pump?
    I'm comparing pressures at a point some meters away from the pump. I also don't have field data immediately after the pump. So after checking my valves, tank levels and setting a reasonable C-factor, i'm tring to reach field data by changing speed factor of the pump.
  • The key to calibration is understanding WHY the model and field data differ. If it is likely that pump speed is in error, that is something you can adjust. Why would you suspect the speed is incorrect? Are you adjusting speed based on a set point or time controls?
