Hi there,
I do not have a WaterCAD license, so I would like to request that Bentley would export the WaterCAD files I have to EPANET files (.inp). I would like to work with the files in EPANET.
Thanks,Josh
Hello Josh,
Kindly share your hydraulic model with us so that we can help you. Save it in File > Save as Package and then forward it following the steps mentioned in article below:
Sharing Hydraulic Model Files on the OpenFlows
Hi Ankit,I have now uploaded the files under "Water_Model.zip". Please export each scenario (one INP for each).Thank you,
Josh
My colleague Luca has shared the files with you by private message. Are you able to open/work on them?
Please reply
Also please tell us if you have any issue.
Yes I was able to open them in EPANET.
