watercad flow supply and demand
I am modelling a system with two elevated storage tanks (with  an operating level of 950.5 and the other at 921.5). I am expecting that the 950.5 will be able to fill the 921.5 tank. The system has two supply wells. To add  supply into the system, i am simply adding a negative demand at the well location. I don't have any information in regards to pump curves at the well locations, just the pump capacity  flow. My current system demand is 2000 gpm. Once I my supply is less than 2000 gpm my model runs with no errors, however as soon as the supply is greater than 2000 gpm, the model give me the following errors: disconnected demand nodes detected. and junction (at various) locations is disconnected from reservoir or tanks?
Parents Reply
  • Do you have any way of getting the pump information for the well? That would be the best option, since you would not only have the flow but the head being added by the pump.
    Otherwise, you would need to know how much head is being added by the pumps and use that to get the elevation. Even this might be tricky in getting stable results. For instance, depending on what you enter, you could end up with flow from the tank representing the well pump into the other two tanks (depending on the hydraulic grade balance in the system).
    Using or approximating the actual well pump information would be the best solution though.
    Scott
