Remove pipes
 How can I remove the last pipes that I add to my network ?
  • Hello Ayend-Christ Daou,
    The easiest way to remove the last item placed in a file (if you have not exited it) is to use <Ctrl> z (Undo).
    After you have exited and re-entered the file, the Undo "buffer" is cleared and Undo is no longer an option.
    Another thing to do is Exit the model without Saving your changes.
    Otherwise, please find the last area of the model you were working on and see if you can use the query in Network Navigator - Network Trace - Trace Downstream and see if you can find the last element placed.
    Another area to look at is at the end of your FlexTables.  Elenments are listed (and labeled) in chronological order unless you change it.
    Hope this helps,
    Larry
    Answer Verified By: Ayend-Christ Daou
    I was also reminded that if you had Change Tracking enabled at the time of placement, you could look back through the logs and use it as an audit trail to see what pipes were added at what date/time and by whom, to help find things they might want to delete.
