In SewerGEMS, the terms "maximum velocity" and "outlet velocity" pertain to the hydraulic analysis of sewer systems. These parameters are critical for assessing the performance and integrity of sewer networks. I am hoping that the technical questions below can be given some guidance. My end goal is to try to understand plunging velocities and trying to make sense of them and I know this outside the scope of the product, as this was mentioned in another post:
Maximum Velocity Calculation:a. What is the mathematical formulation or algorithm used to calculate the maximum velocity within a sewer conduit in SewerGEMS?b. How does SewerGEMS account for variations in pipe size, shape, and flow rate when determining the maximum velocity?c. Can you explain the role of boundary conditions and roughness coefficients in the calculation of maximum velocity?
Outlet Velocity Calculation:a. How is the outlet velocity from a sewer pipe or junction computed in SewerGEMS?b. What specific hydraulic principles or equations are utilized to determine the outlet velocity?c. Does SewerGEMS consider factors like downstream pipe conditions or outfall characteristics in outlet velocity calculations?
Manhole Velocity Calculation:a. What methods or equations are employed in SewerGEMS to calculate velocities at manholes within the sewer network?b. How does SewerGEMS handle the transition of flow velocity between pipes and manholes?c. Can you elaborate on any unique features or considerations in the calculation of velocities entering and exiting manholes, especially in the context of complex sewer geometries?
Boundary Conditions and Assumptions:a. What assumptions and boundary conditions underlie the velocity calculations in SewerGEMS?b. Are there scenarios or conditions where the velocity calculations may deviate from real-world conditions, and how does SewerGEMS address such situations?c. How does the software account for unsteady flow conditions or transient events in velocity computations?
User Customization:a. To what extent can users customize the velocity calculation methods in SewerGEMS to match specific project requirements or regional standards?b. Are there parameters or settings within SewerGEMS that allow users to fine-tune velocity calculations for particular sewer system designs?
Hello, Daniel,I would like to recommend that you check out our explanatory material on all the theory related to SewerGEMS in detail and if this still leaves you with any doubts, please get back to us and we will help you.
Help topic > Theory > Fundamental Solution of the Gravity Flow System.
Luca BillisTechnical Support Engineer, OpenFlowsBentley Systems, Inc.
To add to Luca's response:
If you can explain a bit more about your project and the reason for all of your velocity questions, it would be helpful.
Other community members may be able to comment on your engineering practice-related questions.
