How do I input my shapefiles and Digital Elevation in Sewergems Update 4 and align it with bingmap with the goal of simulating urban flooding?
Using Sewergems Update 4
  • Hello Gussie,
    Please elaborate more on what you want to do with more details.
    What I sense is that I am trying to explain in following points -
    "I input my shapefiles"
    1. To develop a model from scratch using shapefiles, you can use a ModelBuilder tool in SewerGEMS.
    If you are using a source file like a shapefile when creating the model file you should make sure to turn on all of your snapping options, so the elements are connected in the source program and there aren't connectivity gaps. You should also make sure that you are laying out the elements in the correct order according to the WaterGEMS connectivity rules. This means that every pipe needs to have some type of node element attached at either end. Node elements include junctions, tanks, valves, reservoirs, and pumps.
    Please see more details in Using ModelBuilder to Import External Data wiki article for more details.
    "Digital Elevation"
    2. The Terrain Extractor (TRex) tool can automatically assign elevations to any nodes based on the nearest elevations from a contour DXF, shapefile, LandXML file, or spot elevations. If you are working in WaterGEMS, SewerGEMS, or HAMMER in the ArcGIS environment, there is the additional ability to assign elevation data based on TIN, DEM or Raster (such as TIF / TIFF) files. Nodes can include junction, hydrants, pumps, tanks, reservoirs, and valves.
    Please see Using Terrain Extractor (Trex) wiki article for more information
    "align it with Bingmap"
    3. Bing Maps can be added directly from the background layers manager (active internet connection required), with the ability to align to the model with up to three points of reference. See more here: Using Bing Maps as a Background
    "goal of simulating urban flooding"
    4. Starting with CONNECT Edition Update 4, 2D Modeling is available directly inside SewerGEMS and CivilStorm(for subscribers only).This enables integration of the FLOOD solver so that you can perform 2D and coupled 1D + 2D simulations in SewerGEMS itself.
    Please go through 2D Modeling of Urban Flooding wiki article with some important links in the See Also section at the bottom.
    Kindly reply if this is not satisfactory and you need more help.
  • im trying to add this shapefiles to my background to account for the elevations but its not showing in the map.  Im also looking for a way to input my digital elevation model which is in asc format
  • Hello Gussie,
    This link has information on the different types of terrain models you can use. If you are using 2D Modeling, you will want to make sure the shapefiles you are using in the Surface Definition manager coincides with the terrain model location. If you need to change the scale or projection, you may need to do this in a GIS program.
    Note that the Surface Definition manager only applies to 2D Modeling. If you want the shapefiles as actual background images, you would need to add them in the Background Layers manager. Surface Definitions are used to adjust the information on the terrain model when model 2D results. See the wiki on 2D Modeling for more information on this: 2D Modeling in SewerGEMS and CivilStorm.
    Scott
Reply
  • Hello Gussie,
    Scott
