PondPack: Receiving error message of "Node not connected to any upstream links. Nodes must be connected to at least one upstream link."
I'm modeling two catchments in PondPack, each going to their own pond and outfall and receive the following message when running Step 1) Design Scenario Configuration in PondMaker:
"Node not connected to any upstream links. Nodes must be connected to at least one upstream link. Link Outlet-U. Upstream Node: RG-U."
That message is tied to my pond, RG-U, but it's linked to my catchment and the respective POE (the message is for both ponds, so not mentioning the other for simplicity). The POE is also linked to Outlet-U, which connects to my outfall, so not quite sure what's going on. Do I need to disconnect everything and rebuild or am I missing something?
