Error message in SewerGEMs during validation
I was validating my model in SewerGEMs and recieved the following message for each of the catchments in the model:
"The EPA Runoff calculations failed for this catchment."
 The user's manual does not give any indication to the source of this error. Does anyone have any insight on the source? I should note that it is my intention to use EPA SWMM to calculate runoff.
  • Hello,
    I would recommend checking the rest of your user notifications for a more specific reason for the failure. Also, check all your data input for your catchments and make sure all the required fields are populated with valid data.
    If this doesn't help, please contact technical support
    Jesse Dringoli
    Bentley Technical Support
    Jesse Dringoli
    Bentley Systems, Inc.
Reply
  • Hello,
    Jesse Dringoli
    Jesse Dringoli
