How to know if pipes are connected or not by a node?
I have transfered a drawing from AutoCAD to WaterCAD V8i and I see the pipes and also de nodes. The problem is that although I see nodes in some pipes that either cross other pipes or that stop (connect) to other pipes, but I'm not sure if there is connectivity or not. How can i check if that node is really connecting both pipes that might be in a "T" or an "X" configuration.
Im in the early part of seting up the model so I can't run it quite yet.
  • One of the things that throws me off is that at certain "T" or "X" connections I do see a node, and the review tool sees them too, but when I click on one of the pipes it highlights the entire section on both sides of the node (meaning that in a T situation it would highlight as two main pipes) so I'm not sure if this is how it's supposed to be or not. Now, when I right click on the node/junction it gives me the option of "Split" and if I do that, then the pipe gets split and not I can highlight as three pipes around the T junction. Do I need to Split every junction for it to be a real connection?
  • Plus when I move the node it moves freely with on of the pipes leaving the otherone behind, if there is a connection between pipes by that node/junction shouldn't all pipes going into the node/junction move while moving the node?
    If so, why is it that when transfering my CAD drawing to WaterCAD it doesn't join any of my pipes and only puts a "floating node"?
Reply
  • To answer your second post, Yes, if all 3 pipes are connected to the node, they should move together when moving the node. Basically you have a single pipe running behind the node, and another pipe that's actually connected to it. Each pipe must have an end node and just because a pipe overlaps a node doesn't mean that they're connected. Connectivity is based on a pipe's start/stop node.
    When you import a CAD drawing, it will not automatically create two pipes instead of one and split/connect to the node. You will need to run the batch pipe split tool mentioned in my previous post. (which will take care of all occurances of this)
    If you have any further questions, please submit a service ticket to technical support.
    Jesse
    Jesse Dringoli
    Bentley Systems, Inc.
  • Re: "why ... when transferring my CAD drawing to WaterCAD, it doesn't join ...pipes [it] only puts a floating node?"
    Nodes will only get created automatically at line/polyline endpoints, so what you are seeing in the model corresponds to how the lines were drawn in the cad file.
    Some of the "Floating nodes" could be valid, so we provide a number of powerful review and fix tools (Network Navigator, and Batch Split to name a few) to allow you to interactively review and decide what gets split.
    If you want to split all elements, you can simply run the Batch Split Tool.
    If you want to selectively split some of the elements -- here is the recommended workflow (from online help).
    Pipes will be split by every junction that falls within the specified tolerance. To prevent unwanted pipe splits, first use the Network Navigator's "Network Review > Pipe Split Candidates" query to verify that the tolerance you intend to use for the Batch Split operation will not include nodes that you do not want involved in the pipe split operation.
    To use the Network Navigator to assist in Batch Pipe Split operations
    1. Open the Network Navigator.
    2. Click the [>] button and select the Network Review...Pipe Split Candidates query.
    3. In the Query Parameters dialog box, type the tolerance you will be using in the pipe split operation and click OK.
    4. In the Network Navigator, highlight nodes in the list that you do not want to be included in the pipe split operation and click the Remove button.
    5. Open the Batch Pipe Split dialog.
    6. Click the Selection button.
    7. Type the tolerance you used in the Network Review query and click OK.
    Rob.
