The results display for a modified rational results has a column for outflow volume target (which displays as N/A) and then shows the outflow volume value and then the next column shows FAIL, as there is no target to compare to. Has anyone any advice as to how to deal with this superficially negative FAIL message?
Hello Jak,
It looks like you're talking about Pondpack V8i. The "N/A" for Target Outflow Volume in the Pondmaker Routing worksheet can appear when you set the "target flow/volume source" to "user defined" in step 1. In this case, the user must manually enter the target flow for each return event. So, the "target peak outflow" and "target outflow volume" fields in the Design worksheet become editable. They are both "N/A" by default, so it sounds like you only entered target peak flows.
With that being said, you may not always need to design a pond to keep the total volume below the predevelopment conditions. Typically this only happens with significant infiltration, otherwise there would be no reduction in postdevelopment volume. So, that means that the "fail" message for "Computed outflow volume vs. target" is not necessarily a problem. If you're not designing the pond to keep the total volume below the predevelopment conditions, you could either ignore this or enter some values for the "Target Outflow volume" in the Design tab of the Pondmaker worksheet and adjust the "volume allowed below" and "volume allowed above" fields in the Options tab.
If you have any other questions about this, please contact technical support .
Jesse Dringoli
Bentley Technical Support
