SewerGEMS v8i Printing Flextables? Data reporting and presentation?
Am I missing something?  Can you not print directly from the software?  I need to export to another application first to print?
A nice feature would be some type of feature that would allow you to manually create standard report output.  The standard reports that are built in are nice and all, but are either very very general, or super specific to elements.
There needs to be a reporting feature that allows the user to not only create the output they need, but also provide some easy reporting features to select what they want.
Perhaps a report for the sanitary loads, where they are located for example as part ofa  collective report for a specific scenraio or alternative, complete with flextables, summaries, etc.
Alot of information seems to get "tucked" in to the software, and is not easy to recall for presentation purposes.  You need to almost be the "USER" to see what is going on.
Integrating profiles and other information into this software ouput/print idea would be very resourceful also.
  • Hello Glenn,
    You can certainly print directly from the software. The plan view and all reports should have a "report" button. For example let's take the conduit flextable:
    This button will open the report window, which you can print using the print button:
    Of course, you can add any fields you'd like to the flextable and rename/resize the column headers at will. You can also set up a Modelbuilder run to export (sync out) any model data (including calculated results) to another file such as a pre-formatted spreadsheet.
    I believe that future versions of SewerGEMS will include a new XML reporting feature, which allows more customization and standardization of your reports. I will let other contributors comment further.
    Jesse
    Jesse Dringoli
    Bentley Systems, Inc.
Reply
  • Hello Glenn,
    Jesse
    Jesse Dringoli
