I am trying to print the flextables for pipes, junctions, etc and I only want to show the active topology. I am using a filter to remove the inactive elements; is there another way to do it?
Thanks!
I would say that the flextable filter on "Is Active?" = "True" is the best way. Another way would be to uncheck "display inactive topology" under Tools > Options > Global, then press CTRL+A to select all elements (only active elements will be selected), right click in the drawing pane and choose "edit group" Open the flextable for the desired element type and it will be filtered to only those elements. You can then copy out or print the flextable contents.
Jesse
