For some reason when I open up a project in ArcMap, I have to go in and manual point the labeling of some tanks to the labels that I've set up in WaterGEMS. I would think that this would happen automatically. Is there some way that this can be done without having to go through and setup the tank labels everytime?
Michael
Hi Michael,
If you would submit a service ticket by going to appsnet.bentley.com/srmanager and submit a more detailed explanation of the problem that you are experiencing with either steps or screen shots of the specific problem we should be able to help you out with answer to your problem.\
Thank you,
Mark
Bentley Technical Support Group
