PondPack v8i - Pondmaker - Design Scenario Configuration
Hi guys,
Hopefully someone can help me.  I can't figure out how to generate Target Peak Outflow and Target Outflow Volume in the Design Worksheet Summary once I try to
"Compute Step 1"  - I have generated predevelopment flows and I set my Target Scenario to the predevelopment data for 2, 10 and 100 storm events.  I put in my storm data and I was able to successfully generate a batch run under Analysis but I can't get the targets to show up in the PondMaker.  Any suggestions?
-Khadija
  • Hello Khadija,
    I would suggest looking at Quick Start Lesson 1 under Help > PondPack Help > Contents > Quick Start Lessons. This will walk you through how to use PondMaker to design a pond and should clarify how to set up the worksheet properly to generate the desired values.
    You can also take a look at the included "Pre and Post Pond Design" model file, located in the "Samples" folder within PondPack's installation folder.
    Basically the target peak outflow is populated by the peak flow at the target element, for the selected target scenario. You'll need to click the "Compute step 1" button to generate this, which will automatically do a batch compute of the pre and post scenarios. If any of the scenarios are not set up properly, the worksheet will not populate and one or more user notifications will display, with guidance as to how to set up the model correctly.
    If the above does not help, please send your model to technical support and clarify exactly what steps you're taking. Compress the .ppc and .ppc.mdb files into a zip file, then submit a service ticket from the Service Ticket Manager.
    Jesse Dringoli
    Bentley Systems, Inc.
Reply
  • Hello Khadija,
    Jesse Dringoli
