WaterCad Select Series 2 Copy Graph Data Problem
I am having problems with copying data from the graph data tab.  My problem is that when I copy all the data the header row is not copied.  So when I paste in excel I have no idea what the data in each column represents.  This woudn't be a problem if WaterCad didn't occasionally change up the order of the columns, but it does....therefore, manually creating a header row in excel once will not solve the problem.  Next time i copy/paste the columns may not match the right column header.
This problem did not exist in Select Series 1.  Basically I use excel to automatically display extended period simulation results since watercad's charting capability is limited and frustrating.
How can I enable watercad to copy the header row?
Matt
Parents Reply Children
