Hi all
I have a question related to unit of K (emitter coefficient). The formula is Q = KPx then Q (l/s) and P (mH20) so I think K will have unit . Is it right ? If yes, should I exchange unit of Q to m3/h or still keep l/s because I wanna unify their unit. Is it Ok ?
Thanks.
Yes, the emitter coefficient has units. Here's a snipit from the WaterGEMS/WaterCAD documentation (this is also in our Advanced Water Distribution Modeling and Management book):
Also, here are the available units in WaterGEMS/WaterCAD for the emitter coefficient:
So, if the pressure is in meters and the emitter coefficient is in L/s/(m H2O)^n, then the flow unit would be L/s
Here's a table from the Help for common hydrant emitter coefficients in different units:
Hi Jesse
Thanks so much for your detail answer. I can move forward my job now.
Thanks again
Please note that a subsequent reply to this thread has been split off into a new thread here: Method to estimate emitter coefficient
