PondPack V8i question
I've used pondpack for many years but am new to V8i.  I keep getting the following error message:
-1 "Predeveloped" "Pond" "44" "Basin 1" (N/A) "The pond elevation column needs to be entered in ascending order." Precalculation
It appears that my pond elevations are entered in ascending order so I am unsure of what I have entered wrong.  Any help would be appreciated, thanks.
  • First, make sure that there are not empty cells at the top or bottom of the list. If there is, this may result is the user notification.
    If not, this is likely related to how the database stored the information. There is an easy fix for the issue. Copy the elevation-area data in PondPack into Excel using the keyboard shortcuts. Next, delete each of the rows from the elevation-area curve in PondPack by highlighting the row and clicking the Delete icon. Now copy the data that is in Excel and paste it back into the elevation-area curve dialog. With this done, hopefully the errant user notifications will not occur.
    If the issue still occurs, please contact Bentley Technical Support: appsnet.bentley.com/.../addcall.aspx
  • That did the trick, thanks for the quick help
Reply Children
