background dxf in stormcad
Hi ALL,
i have a very simple problem which is that when opening a base map in dxf format as a background.the dxf appears not correct at all with rectangules with diagonals.
i dont know why??
stormcad is SS3 and dxf file is from autocad 2010
BR,
Rasha Yehia
  • Hello Rasha,
    It would be best to send the dxf to technical support for review. This will ensure the most timely response from an available analyst.
    Some quick things to try:
    1) Open some of the included sample files to ensure that their background dxf loads without a problem. If they have the same issue, then the problem may be on your computer (perhaps a video card driver issue)
    2) Save down the dxf to an older version such as 2004 or R12
    3) Ensure that you have the latest version and cumulative patch set applied. Te latest version of StormCAD is 08.11.02.75, which is SS2.
    4) If the same problem occurs when making a bounding box (click+drag to select multiple elements), try toggling the "use accelerated redraw" option under Tools > Options
    If these do not help, please contact technical support.
    Jesse Dringoli
    Bentley Systems, Inc.
Reply
  • Hello Rasha,
    Jesse Dringoli
