问题1 ,附件上传不了
问题2 ,我做的模型,分析|验证 没有发现问题,但是一旦进行水力模拟就出问题,显示引擎计算失败
Question 1, annex can not upload
Question 2, I do model, analysis | validation found no problem, but once the hydraulic simulation problems, engine computes failed
There are many reasons why the calculation may fail. The first place to look for help in resolving this is the User Notifications, which normally appear automatically. This will tell you about any specific problems in the model.
If you do not see anything useful in your user notifications, the next step would be to do a general check of all data input in the model. Make sure everything is entered correctly in the correct units. If possible, it is also a good idea to ensure you're using the latest available version. You can check your version under Help > About. The latest version of WaterCAD and WaterGEMS is 08.11.03.19.
If this does not help, you should submit your model to technical support for further help. We may have an analyst that speaks your local language for any translation needs.
