Model Spring Flow
I'm trying to model a spring with a flow of approximately 1,000 gpm.  The flow is set by a weir prior to entering the water distribution system.  The spring has the highest elevation in the water system and if I don't include a flow control device then the spring will flow at 2200 gpm which it will not physically do.  What is the best way to model the spring and limit the flow out of the spring to reflect actual conditions using WATERGEMS?  Thanks.
