Hi,How to draw a pipe layout . The case is "a Pump pumps in water from a underground tank to a tank on a building". Now as in water cad we insert a tank on the building and connect it to a pump and inturn connects to the U/G tank. BUT we have to provide the min, max levels in the tank properties. But the actual thing is we are just filling that tank which has a demand of 5000 litres. So how can we simmulate this on water cad? I hope you understand the scenario.
When you add a demand to a tank, what you are specifying is the amount of the water that is being used by customers at a tank.
When you talk about a demand, you need to talk in units of flow per unit time.
The tank in a model is a known hydraulic grade and the model tells the user what flow is going in or out of the tank.
I encourage you to sign up for some of our on-line training and read up about modeling basics in our documentation and our "Advanced Water Distribution Modeling and Management" book.
www.bentley.com/.../AWDM.htm
