Hello there,
I have a problem with my hydraulic check value. It is not showing correct level of fluid.
What should I do, where should I get it repaired from?
Any suggestion will be greatly appreciated.
Hi Bruce,
It sounds like you have a mechanical problem and if so, you _may_ not hear any recommendations. What about contacting the manufacturer?
If it's a hydraulic modeling issue then please let us know some more details.
