System Head Curve IS NEGATIVE IN ALL PROJECTS
Dear ;
In all water projects using watercad or watergems, the system head curve gives negative value which is not correct at all. I attached one project for your review. I appreciate if you can check the system head curve for the attached project.
Thanks in advance
Sayed Ali
Saudi Consulting Services
New folder.rar
