Dear,I can not global edit diameters of pipes, I get syntax error. Someone can help me?I have installed Watercad v8i select series 4
Is the value between the quotes in this case a Pipe ID or Label?
Does this happen on Globally Editing any field, or just for Pipes?
Are you currently using a Filter on the Pipe Flextable?
It may be helpful to take a look at the model in this case. You may want to submit the model to our Technical Support team. The following link describes this process in depth.
communities.bentley.com/.../bentleysecurefilesupload.aspx
Dan Iannicelli
Technical Support Engineer
Hello Dan,
1. The value is a number unknown to me, but depends on the number that is entered as diameter
2. It happens using global edit, specifically in pipe diameters. However, the global edit use in the roughness operates.
3.I have two filters in diameter and materials
4. Field can be edited manually
Thanks for you help
If you could please upload the model using the link I mentioned I can take a look.
Dan
To update users in the forum, this issue appears to have been resolved by installing the latest release of WaterCAD/WaterGEMS with the latest patch set. If anyone runs into this issue in the future, please consider upgrading to the latest release.
See the following solution wiki for some additional information:
communities.bentley.com/.../error-message-when-using-the-global-edit-function.aspx
Scott Kampa
Bentley Technical Support
