Hi All!
I have a model with multiple scenarios, each with different topologies and demands. For each scenario I need several different reports (junctions, pipe, pump, etc). Total, this will give me a few hundred different reports.
Is there a way to run (print) multiple reports or tables at the same time?
Essentially, I want to click just a couple buttons and print everything happening in the active scenario without having to go back and forth to the different types of elements. Besides wasting time, going back and forth is just begging for errors.
Any thoughts and advice would be HUGE!
There is not a way to view and print multiple reports directly. However you may be able to use Modelbuilder to export the properties you want for multiple elements into a single file, such as an Excel spreadsheet. The following solution wiki has details on how this is done:
communities.bentley.com/.../reporting-for-multiple-elements-at-the-same-time.aspx
Please let me know if you have any additional questions.
Scott Kampa
Bentley Technical Support
