Question of Darwin Designer1
Hello
In ‘Darwin Designer’ and in it’s ‘boundary override’, I set closed ‘value’ for a pipe attribute (pipe status), then run the design machine. When it made design for my model, I look at the ‘pipe’ which had been assumed ‘closed’ and it’s status was ‘open’ (in it’s properties) and darwin designer had designed it.
Somebody tell me why what I set as ‘boundary override’ was ignored when run.
Photo has been attached.
Thanx
Mohsen.amiri@gmail.com
