Variable speed pumping from EPANET to WaterGEMV8i
Dear Colleagues,
I have made a model in EPANET. The model includes a constant speed pump. Later I have imported the file in to the WaterGGEMV8i. I made an alternative for variable speed pump. The scenario with constant speed works, but child scenario with VSP generates message: Variable speed pumping is not suported by Epanet.  Results may not match EPANET.
Only to add that number of message is 41797
