unsuccеssfull trials for energy cost calculation
Dear colleagues,
I have made working scenarios. When I use "scenario energy cost" tool, the energy usage is obtained (kW/ML), but prices remain 0 (zero). Although the energy pricing is filled up and picked (in column include energy calculation) after.
  • Here is a technote that may help you to make sure you have your data set up properly.  There is also a quick start lesson on energy cost that may help you identify what is causing the prices to remain at zero.
    communities.bentley.com/.../energy-cost-analysis-in-watergems-v8i-selectseries-4.aspx
    Make sure that you have gone into the energy cost alternative and selected the elements to be included in the energy calculation.
    Terry Foster
    Technical Support
    Hydraulics and Hydrology product line
    Bentley Systems, Inc.
  • In addition to checking units and the setup of your Energy Pricing, another thing you could look at is the "EngCostLessonFinal.wtg" file, located in the "Lessons" folder within your WaterCAD/WaterGEMS installation folder. This example model has scenario energy cost configured already, so you can compare the setup with your own.
    If you need further help, consider sharing your model files. There are two options for sharing your files on BE Communities. If you would like other members to be able to see the files, you can upload them as an attachment using the ‘Advanced Reply editor’ before posting. If your data is confidential, you can follow the instructions in the link below to send it to us via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley.
    communities.bentley.com/.../bentleysecurefilesupload.aspx
    Jesse Dringoli
  • Hi Jesse,
    I have send the files with name B.Sl.
    So the problem is that scenario energy cost tool works when price pattern is time of the day and it doesn't work when it is constant tariff.
  • Borisov,
    I understand your issue and I'm currently looking into it. In this situation what I'd like to do is have you create and submit a service request so we can more easily track the issue and provide it with more direct attention. You can do this on the Bentley website through the service request manager found here: appsnet.bentley.com/srmanager   In your service request please just reference that you have already posted on the forums about this issue, so that we can easily identify your request.
    Mark
    Mark
