Fixed Flow Simulation Using Watergems
Hi everyone,
Could Watergems run an EPS simulation by using fixed flow profile instead of pressure profile as a boundary condition. The inlet flow profile will acting as (+ve-give water) intead of (-ve -using water). Because sometimes data for inlet pressure profile is not unavaible so we could used others method to run the model.
One more things, could Watergems create transfer node?
Hope somebody will explain about this matters.
Thank you.
