StormCAD 08.11.02.75 Microstation 08.11.07.443 --- StormCAD opens the dgn OK but when I go to Tools > Layout > any entry the element does not show and does not draw into the dgn. The Project appears to be set up as needed. This is the 1st time using StormCAD. Any suggestions? thanks Bob
Can you please explain this situation in a little more detail?
Are you able to click on the specific elements?
Do you know if you have a StormCAD model attached to the DGN?
A little more information will be very helpful.
I am able to click on the Tools > layout > then any element icon; however, nothing appears @ my cursor or in the drawing.
The only model is default...should there be a stormcad model created?
Hey Bob,
I have recently sent you a message with a Service Request. Please respond to that Service Request. If you did not get any email for some reason, please send me a private message. It might be beneficial to check the Junk mail folder. Please let me know.
Dan
Answer Verified By: Bob Mullenix - MtDOT
The problem was with the original drawing files used when opening StormCAD. I recreated the SEED file and, when using it as the base DGN, then referencing in the original drawing, everything works as expected.
I sent the old seed file to Bentley for analysis.
