Is it possible to select multiple ,, junctions,, together and change a property ?in other words : to assign a value for a property of a 50 junctions together by selecting them from map?
Here's a way:
1) Select the elements that you want to edit2) View > Flex Tables3) Right click on the interested element (like Junction) > Open on Selection4) [If the column/field that you want to edit is not visible, click on Edit button and add the field]5) Right click on the field you like to edit > Global Edit6) Select the right option from the dropdown, like Set and enter the value you like.7) Click OK
That should do what you are looking for.HTH.
Answer Verified By: Maen Abdulhaq
very helpful!
