Flushing Event Order Duplicates - Error Message 41838
After adding a flushing event and running the flushing module (for all events) I receive the subject message "Flushing event order duplicates at least one other flushing event".  If I delete any event then I receive no notification.  However, once I add another event I get the same message.  Is there some way to "re-index" the flushing order?  Note prior to the message,  I had manipulated the Events within the Study by moving some up, moving some down, deleting a few Events and renaming most.  None of this was done all at one time, rather as I worked along in the flushing Study.  Any assistance is appreciated.
-Matthew
Parents Reply
  • Hello,
    We have rectified this issue in WaterCAD 10.00.00.50 version and created a patch for that, i will contact you offline for that and provide you patch for WaterCAD 10.00.00.50, which should resolve the issue.
    Also we have resolved this issue in WaterCAD 10.00.00.55 version, so you may consider upgrading to WaterCAD 10.00.00.55 version.
    Sushma Choure
    Bentley Technical Suppport
