Reports
I'm using SewerGEMS latest version 08.11.03.84.
I would like to be able to issue a report per each node/conduit/pressure pipe with following data:
  • ID
  • Diameter
  • Length
  • Slope
  • Velocity
  • Headloss
  • Base Flow
  • Flow
  • Invert level
  • Ground level
  • Pressure in pipe (for pressure pipes)
How can I do that?
Alex Bekker
  • Hello Alex,
    If you want to set the reports for e.g. conduits as per the list given by you, then simplest way would be to edit the flex table accordingly.
    Please go to Report>Element Table>Conduit Flex Table>Edit the flex columns as per the fields you require, you can add or remove the fields. See the snapshots.
    Sushma Choure
    Bentley Technical Suppport
  • You can also use a 2-Row Flextable to display conduit and adjacent node information. Example:
    For the pressure pipe and pressure junction information, you'll need to set up separate reports using the Pressure Pipe and pressure junction flextables.
    Jesse Dringoli
    Bentley Systems, Inc.
Reply
    Jesse Dringoli
