I use multiple efficiency points option. After that I test scenario energy cost, but the WGems does not calculate full energy usage in scenario energy cost.
This is not the case when I use the option best efficiency point. Then everything works with energy usage.
Things will work a lot better when you enter efficiency in the right units. Try 60% instead of 0.60%.
Very common mistake.
Answer Verified By: Boyan Borisov
