This dwg file seems like it should be very small, but it is 8 MB. I opened it with Mstn Connect Update 1, did a SaveAs command and the result was a 30MB file! Why would saving a file increase it's size by a factor of 4?
Sheet Index.dwg
--Thanks,--Robert
Hi Robert,
I opened your file here and added a linestring and then save the file as a new DWG file. The file resulting file was only about 32Kb bigger. See the attachment.
Was this file located on network server, try saving it locally and see if you get the same results.
Sheet Index_2.dwg
Answer Verified By: RobertArnold
