How to create i -model published and If any add-in is required then please provide the link.
what product do you use and how do you want to consume / use the i-model?
With regards,
Jan
Hello Jan
I am using water gems Connect version. I want to see the 3-d profile of pipeline.
ankr ankr said:I am using water gems Connect version.
I recommend to move your question (use More > Move under your original post) to Hydraulics and Hydrology forum.
Every Bentley product is different and i-model export is implemented in a different ways, so answers will also be different for e.g. MicroStation or Water Gems.
Hello Ankr,
For publishing i-models you need to run the i-model publishing engine first, which can be downloaded using software downloads.
i-model Publishing Engine for Hydraulics and Hydrology Beta 1 (English) 32-bit
Downloading OpenFlows | Hydraulics and Hydrology Software
Below link explains how to create i-models in WaterGEMS.
What is an i-model and why does it show as a prerequisite? How do I publish an i-model?
Sushma Choure
Bentley Technical Suppport
Answer Verified By: ankr ankr
Thanks Sushma.
