Could someone please explain exactly difference and use of passport vs visa? According to the link below, it said passport can use for PW apps including Navigator (I assume it means both CONNECT and DGN versions), but support said otherwise.
And visa can be used for PW Deliverables Management, what does PW Project Sharing use then? Passport or visa. What if the user is from external company collaborating with us using PWDM and/or PWPS, do they get charged for the use or do we get charged to pay for their use?
Are those mentioned in the link still true with Bentley Cloud Services Subscription/PW CONNECTION Services?
Please clarify as I could not locate the info I need for these. Thanks.
www.bentley.com/en/about-us/news/2015/november/02/bentley-cloud-services-subscription
Unknown said:For the Navigator Connect edition, could I confirm if I understand correctly here that the mobile app version requires only passport, desktop version requires only visa and works only when Cloud Services Subscription is active? Running desktop version without CSS active for a site will Only get in trial demo mode and will not get charged?
Yes, your understanding is correct. I confirmed with a Navigator product specialist that Navigator Mobile only requires the CONNECTIONS Passport.. I also verified that the desktop version of Navigator CONNECT edition requires only a visa provided through a Cloud Services Subscription. I reconfirmed that attempts to use the desktop version of Navigator CONNECT edition apart from a visa will cause the product to run in trial mode and that such usage will not be considered for billing purposes.
Unknown said:But we seem to be able to run the desktop version and log on to Enterprise project portal and view file from there. I'm sure we have not activated CSS and bought any visa, we only have passports. This somehow seems not matching the license requirement for Navigator Connect edition you mentioned, hope we are not getting surprise Quarterly Term Licensing bill shock!
Are users of the desktop version running the CONNECT edition or an earlier edition such as V8i? As mentioned originally, editions prior to the CONNECT edition are covered by the CONNECTIONS Passport. Only the CONNECT edition requires a visa. If running the CONNECT Edition apart from a visa, note that the product is still functional during the trial period.
The following table provides a summary of what licenses are required for Navigator products:
License Required
Answer Verified By: DanG
