I have one license that I use on multiple computers. When I tried to use the Microstation in my desktop switching from the lop top. I got a message stating I can not access it because I only have one license. It is my understanding that I can use one license on multiple computers so long as one user is using it at a time.
How do I resolve this problem? I know for a fact that there is no one using the license at this time.
Thanks.
Are you receiving a message that no checkouts remain because the license has been used on one computer today? If so, please refer to the following support solution for an explanation.
Unknown said: It is my understanding that I can use one license on multiple computers so long as one user is using it at a time.
Also an equally important article would be Understand, Monitoring and Managing Usage.
With the benefit of Bentley SELECT pooled licensing, you are in fact able to utilize your single license on multiple machines. However, please review the article to confirm that your usage is in line with the SELECT Agreement.
Hope this helps!
