I have a problem with de model because this only permit 10 pipes and I need more. In HELP and about watercad in size is 10. I need more. What am I do?
If you own or have access through SELECT Open Access to WaterCAD licenses with a higher pipe limit, configure WaterCAD to use a higher pipe limit using the Municipal License Administrator. Please note that the use of WaterCAD licenses you do not own, known as term licensing, will be billed later, so please consult with your management before proceeding.
