Hi there,
I have downloaded Bentley Hevacomp V8i (English) 32-bit from the software downloads.
Unfortunately, as I have installed the software, there is no prompt to insert the activation key. Also, all the files show a pop-up windows error.
I was hoping someone could help set up the system.
Kind regards,
Arafat Hossain
Open the Windows Start menu, type "License Management Tool" in the search filed, and select License Management Tool from the search results. Select Product Activation Wizard from the Tools menu, and proceed through the following activation instructions for our hosted SELECTserver. Afterwards, please configure your products with the correct feature levels using the Municipal License Administrator. This will ensure that the proper licenses are used.
