Why do I keep seeing this notice? It pops up occasionally, but not every time I start MicroStation...
If I click the More Info link it takes me to a Be Comminities page that no longer exists:
Unfortunately, the page you've requested no longer exists. Please use the search form above to locate the information you're interested in.
If I click the Sign In or Continue link, nothing much happens.
Possible explanation for this dialog can be found here https://communities.bentley.com/products/licensing/w/licensing__wiki/40445/offline-usage I se that your down to the last day, have you been unsuccessful in logging into the CONNECTION Client ?
If experiencing Login / Licensing issues, please raise this in the Licensing & Activation Forum and/or Cloud and Web Services Forum for further investigation. See also https://communities.bentley.com/communities/other_communities/sign-in_assistance_and_web_services/w/wiki/33057/connection-client-fails-to-sign-in
Carl Myhill
Technical Support Engineer
Bentley Systems
Carl Myhill said:I se that your down to the last day, have you been unsuccessful in logging into the CONNECTION Client ?
This dialog appears sporadically and independently of the CONNECTION Client. I successfully sign-in to CONNECTION Client from several accounts automatically.
As a troubleshooting measure, please upgrade to CONNECTION Client 10.00.13.17 or later. This version includes some bug fixes pertaining to offline mode and communication with the Bentley Licensing Service that may help. Do the sporadic sign-in messages cease?
Jeremy Hoesly said:upgrade to CONNECTION Client 10.00.13.17
My CONNECTION Client is updated to that version. However, I continue to see the Sign In Required dialog, even when logged-in automatically to CONNECTION Client.
Same for me. Huge disappointment. Continuous loop of not being able to sign in.
