Hello, Im new here, i just wanted to know how to activate staad pro v22? I have the license key for this product, but i can't find a way to activate this product. My trial is expired already. Thanks!
Hi Nestor,
Please follow the activation instructions given in the support communities link; https://communities.bentley.com/products/licensing/w/licensing__wiki/4987/activating-against-selectserver-online-a-bentley-hosted-server-tn
Abhishek
Hello, Where can i download the application on the link you provided?Because i have the latest version and the instruction you sent is way too different from what im seeing on the application installed on my desktop.
After pressing next.
It say's here that the expiration date is 1/30/2019. But whenever im trying to open the STAAD PRO it says that my trial is expired.
Thanks!Nestor
Sorry for the wrong link. For connect edition activation key is not required to activate the products. Have you sign-in into the CONNECTION client? In order to activate the licenses you need to first sign-in to CONNECTION client. Please see this support communities link; https://communities.bentley.com/products/licensing/w/licensing__wiki/40262/how-to-activate-products-under-connect-licensing
Regards,Abhishek
Hello, Yes, as you can see i already logged in on the connection client and i can't find anywhere i can input the license key i bought. All i can see there is how to activate a product with trial only. Thanks.
HI Nestor,
For connect licensing activation key is not required. The screenshot shows that access to Staad.Pro is 'Denied'. Your account administrator needs to add Entitlement to grant access to use Staad.Pro. Please contact your administrator for this.
