Hey!
I got to test the microstation connect edition for three months. I got a code (key) that I would enter when I downloaded the program from your website. I followed references from you when I was going to download the microstation connect edition program.
But in one step you wrote that you have to put in their code (Key) that I got from you. But when the program had finished loading it did not come up with a box where I would enter the key (key) that I received from you. Without it, my program states that I only have 7 days to use the program.
How can I now when I have downloaded the program. Go back and enter the code I got from you.
thanks for help
The method of licensing your installation of MicroStation could depend on the type of purchase you made and possibly the type or even term of your contract with Bentley. If you are a SELECT customer then you should be able to verify your Activation key against a Bentley Hosted licensing server. You should check that you can verify this key in the License Management Tool.
https://communities.bentley.com/products/licensing/w/licensing__wiki/6175/license-management-tool
If you have upgraded to use Update 11 of MicroStation CONNECT Edition then you would need to login to the CONNECTION Client with your Bentley account to obtain a license.
https://communities.bentley.com/products/licensing/w/licensing__wiki/37813/connect-licensing
If you have further questions regarding the licensing of your software I would suggest calling your local Technical Support phone number.
https://www.bentley.com/en/about-us/contact-us/offices
