Greetings,
I'm happy to see that we will have some geo-fencing capability with CONNECT licensing. Is there any way that we can do this with SelectServer to restrict usage to IP addresses inside the US?
We sold off some overseas offices a few years ago and they had our site activation key. To block this usage, we currently use client access restrictions. These worked well for a while, but we're now fighting issues with VPN tunnels and remote workers. A geo-fencing option would really help.
Thanks!
Terry Kee
Terry Kee said:Is there any way that we can do this with SelectServer to restrict usage to IP addresses inside the US?
SELECTserver does not provide support for country-specific restrictions. However, you can create Allow rules with IP address ranges as described in the following United States IP Address Ranges resource. To make it less painful, create more expansive Allow rules and exempt certain ranges with Blacklist rules. Such an undertaking is not trivial, so you may want to consider having your site activation key reset by our licensing team instead.
Thank you Jeremy.
