Bonjour,
J'essaye d'activer microstation v8i en NON SELECT, je mets bien le numéro de série, mais lorsqu'il faut que je me connecte avec l’outil "CONNECTION CLIENT" il me dit que je n'appartiens à aucune organisation?!
Comment faire?
Translate:
I'm trying to activate v8i microstation in NOT SEL, I put the serial number, but when I have to connect with the tool "CONNECTION CLIENT" he tells me that I do not belong to any organization ?!
How to do?
For V8i version there is no need sign-in into the connection client. You would need to checkout the license in License Management Tool and use the product. Please follow the instructions given in the support communities link for how to activate non-select licenses; https://communities.bentley.com/products/licensing/w/licensing__wiki/5278/activating-as-a-non-select-or-node-locked-user-tn
