Bentley Systems would like to inform you that an issue was discovered and fixed in the CONNECTION Client that has been determined to have more consequences than previously thought. This issue affects CONNECTION Client 10.0.12.08 installed on non-English versions of the Windows operating system that is connected to a domain. This version may cause extra load on the Active Directory domain controller which could impact users trying to access their Active Directory accounts.
This issue was fixed in the CONNECTION Client 10.00.13.17. It is recommended that you upgrade your version of CONNECTION Client to the latest available, particularly if you use a non-English version of Windows. Upgrades are available through the Applications tab in CONNECTION Client or may be downloaded from the Bentley Fulfillment Center
